Never disconnect the battery to see if the alternator is bad. If it is good, the voltage could go very high and damage the electrical systems in the car and even wipe out the light bulbs. Instead, check the voltage AT THE BATTERY with a good voltmeter with a charged battery, the engine idling, headlights on, and the heater fan running. You should measure 13.5 to 14.5 volts. If the voltage is low, the alternator is weak.
Jan 18, 2006 at 6:03 AM
