93 lumina Z34 runs tell it is warm and dies
1993 ALL OTHER MAKES ALL OTHER MODELS
PTHILLTOPRC
I cant find the crank sesor is it by the trans of dampener on front , I was driving down the road and it died after 15 min it started but only went one block and died changed filter and did not help i went back 4 hours later and got in it and it made it home 8 min drive pulled in drve way and it died so my friend sayes it needs a crank sensor mybe, i have it but whare does it go .any help please O yA it has a 3.4 dohc I did test the plug wire after it dies and thare is no spark
May 14, 2007 at 4:39 PM
PJCANT
Go to autozone website type your car type and they are a online repair that will tell you where the crank sensor is. Make sure you put all the correct info on.
May 20, 2007 at 2:02 PM
PTHILLTOPRC
[quote:b4031215d1="pjcant"]Go to autozone website type your car type and they are a online repair that will tell you where the crank sensor is. Make sure you put all the correct info on.[/quote:b4031215d1]did that and it was igniton moduel
May 20, 2007 at 5:19 PM
