Truck usually after it has hits operating temp it will lose power & start to miss. It will idle perfect but will not pull it's self .If you shut the key off for a split second it will start & run normal for a short while, then do it again only sooner & sooner.I have replaced the relays ,computor,fuel pump,plugs,wires,temp sender to the computor.About 3,000 miles ago I replaced the head,timing belt.This has really got me stumped!!!!When it running it runs great but it seems to have develovped this problem.Could it be a ground everthing seems to be connected.
Feb 19, 2006 at 1:33 PM
