1992 Honda Prelude Dash Lights Out
1992 ALL OTHER MAKES ALL OTHER MODELS
WALK4739
My 92 Prelude has recently had a set of problems. The parking lights, shifter lights and speedometer light have all recently stopped working. In addition, the dimmer switch for the dash has stopped working as well. I thought it may all be connected to a fuse problem and have checked every one I can think of, but they all are fine. Any suggestions?
Thanks
May 13, 2006 at 6:45 AM
LOSONE
  • 1,616 POSTS
Sounds like you have a ground proble. Remove and clean all grounds connected to the battery including the battery to the engine, battery to the frame and engine to the firewall. They must be shiny clean
May 13, 2006 at 7:18 AM
Suggested Repair
Clean all grounds connected to the battery, including battery-to-engine, battery-to-frame, and engine-to-firewall connections, until the contact surfaces are shiny.
Conversation Summary
A 1992 Prelude owner reported that the parking lights, shifter lights, speedometer light, and dash dimmer switch all stopped working. The fuses that were checked appeared fine. The expert suggested a ground problem and recommended removing and cleaning the battery, engine, frame, and firewall ground connections until they are shiny.
