92 Lexus Headlight Wiring
1992 ALL OTHER MAKES ALL OTHER MODELS
DYS
92 Lexus ES300 93000 miles - The wiring into the low beam connectors is broken on both lamps. Is it possible to just replace the connectors with new ones or do I have to replace all or part of the wiring harness to which the connectors are attached? If harness replacement is required what is the approximate cost of the part? Thanks.
Jun 25, 2007 at 10:58 AM
BRUCE HUNT
  • 3,754 POSTS
I would replace just the connectors if I had access to them. I would purchase some of the shrinkable covering to insulate the connections that I would solder. Should be as good as new.
Jun 26, 2007 at 1:56 AM
