92 astro van brake problem
1992 ALL OTHER MAKES ALL OTHER MODELS
SPEEDYJR75
i have a 92 astro van 135093 miles on it with all wheel abs i just replaced all of the lines from the abs block and have bled them yet i still have no brake on the driverside front currently the abs is unhooked because i wasnt able to stop hardly at all with it unhooked im able to stop but still do not have alot of brake pressure and the rear brake constantly lock up as the van slows down the passenger front is working but doenst have enough power to stop the van like it should i have bled all of the brakes and had the abs system checked but still cant figure out what is the problem i have thought of replacing the driver front caliper to see if that fixes the problem but i dont want to spend the extra money i really dont have if i dont have to.
Oct 29, 2006 at 2:37 PM
ROKKYCO
You really need front brakes. The rear ones never work anyway. But the 92 is a beast.....will run forever unlike the 96+ models. So I agree to change the calipers probably on both sides while you're opening up the lines.
Oct 31, 2006 at 11:31 AM
