88 corolla fx-124000 miles - knocking noise from the engine
ALL OTHER MAKES ALL OTHER MODELS
NCCHETAN
  • 7 POSTS
I was earlier not able to crank the car. After letting it sit for a couple of weeks I tried starting the car after putting in a Quart of motor oil, and it started just fine.
The engine sounds fine on low idling. If I hit the gas pedal (even in Neutral) I hear a continuos knocking sound from near (or from?) the engine.
Apr 27, 2006 at 6:07 AM
LOSONE
  • 1,616 POSTS
Is the knock from the top or bottom of the engine?
May 1, 2006 at 4:23 AM
NCCHETAN
  • 7 POSTS
It appears to be from the op of the engine.
Thanks for you reply.
May 1, 2006 at 11:53 AM
NCCHETAN
  • 7 POSTS
*top* of the engine
LOSONE
  • 1,616 POSTS
A top engine knock may be associated with a timing belt about 1/2 tooth off. If the belt breaks it's goodby top of the engine. How long since the belt has been changed. The water pump is cam belt driven also and could be the noise. Let me know.
May 1, 2006 at 1:31 PM
