87 pralude wont idle, just dies?/
SCOTTY2231
  • 1987 ALL OTHER MAKES ALL OTHER MODELS
I just picked up an 87 pralude, when I start it it will idle untell it heats up. Then it just wants to die, every time I push the clutch wile slowing down or if its in nutrol. What could be the problem?
also the o-ring/or gasket on the water pump just blew out, do I need to replace the hole water pump?
Saturday, July 1st, 2006 AT 6:30 PM
JMJJ27551
God help us if you did not do this on purpose. The name of the car is Prelude not pralude, among other spellings in the short paragraph, Jethro
Thursday, October 5th, 2006 AT 2:48 AM
BRUCE HUNT
  • 3,754 POSTS
OK his use of the English language is unique but see through it.
Fuel injected or carbed? If it is carbed I would suspect you need to make an adjustment to the idle.
On the water pump, they aren't all that pricey and though they are work, I would seriously replace it and I would stick in a new timing belt as well.
Thursday, October 5th, 2006 AT 7:34 AM
