2.7 engine oil
ALL OTHER MAKES ALL OTHER MODELS
BERNSAX
  • 14 POSTS
I read with interest the post a few days ago concerning the 2.7 engine. I notice their have been no replies.
I bought a 2004 Stratus last Feb. that also has the 2.7 engine. AT the time, I really didn't know it was a problem engine. I guess I didn't do the research prior to buying it.
After I bought it a friend of mine who is a floor manager for a local used car dealership advised me to have the timing chain tensioner changed at about 50,000 miles. I'm sure everyone one this board is familar with the timing chain problems with this engine.
However, after posting this on another car repair site, the advise I got was just keep the oil changed regularly. One person advised adding 4 oz. of STP at every oil change. Others say not to add STP.
I am using 10W30 Castrol. Hope it works out.
Has anyone on this board had success with the 2.7 engine?
If so, what is the secret to keeping the timing belt from causing problems?
I appreciate any and all advice.
Aug 5, 2006 at 2:11 AM
SERVICE WRITER
  • 9,123 POSTS
I just got information on a recall or re-imbursment or somthing about these motors from Chyrsler. I'll try to find it and pass it along.
Aug 7, 2006 at 1:52 PM
SERVICE WRITER
  • 9,123 POSTS
chysler may re-imbuse for engine troubles
1-866-332-3746
Aug 8, 2006 at 9:54 AM
MIKEYBDMAN
  • 623 POSTS
[quote:a7b4333338="bernsax"]I read with interest the post a few days ago concerning the 2.7 engine. I notice their have been no replies.
I appreciate any and all advice.[/quote:a7b4333338]
I dont see any service bulletins or recalls for your type of make and model engine. If there is a problem with this engines timing chain, then taking it up with a class action suit may be a route to take. But if I understand you do not have a problem with this yet, correct?
If your timing chain will not last but 50k on a vehicle, I would not have the car. I have never had to replace a timing chain on any vehicle I have ever owned. (Never owned a 2.7L)
but from what I have found in the service manual, there is no listed time to replace a timing chain. You should replace your serpantine belt every 60k miles, but a timing chain should last the average life of the car.
My simple solution for never having a oil related failure on any car I have ever owned is this. Change the oil every 3k-5k miles depending on your driving style. Every 50k miles I add one quart of Dura-Lube. I am not hear to promote any type of oil additive, and I am sure it will open up a huge debate, but I just had to replace a leaking intake manifold on my grand prix. Since it had 145k miles on it, I decided to get the heads done and see if I can make the engine last another 145k miles. My machine shop complimented me on the "0" wear on the valves and guides, and I could not find any measurable wear on the cylinder walls. If I had just changed my oil regularly would the wear have been the same? Maybe. But I stick with what works for me.
Aug 8, 2006 at 11:09 AM
SERVICE WRITER
  • 9,123 POSTS
[quote:a783447eaf="Mikeybdman"]I dont see any service bulletins or recalls for your type of make and model engine. If there is a problem with this engines timing chain, then taking it up with a class action suit may be a route to take.
My simple solution for never having a oil related failure on any car I have ever owned is this. Change the oil every 3k-5k miles depending on your driving style. [/quote:a783447eaf]
I was not accurate on the possible recall. Our Jasper engine salesman gave me a copy of the Lawsuit against Chrysler on the 2.7 motor. See my above post for more info through that link, and use the phone number to make a claim.
The problem with the sludge build up has nothing to do with changing oil on required intervals, although some dealer had used that to reject claims. The problem is that there are hot spots in the casting of the block that burn the oil and create a sludge condition. This blocks oil going to the timing chain as I understand it.
I don't recall having to get into any of these motors under this situation. I have heard some be noisy.
Aug 8, 2006 at 12:39 PM
