2009 Questions for all other cars Air Conditioner cycling
2009 ALL OTHER MAKES ALL OTHER MODELS
1,200 MILES • 4 CYL • 2WD • AUTOMATIC
MOJAVA
I just bought a NEW foreign car as I live overseas.
From the day I bought it until now....no matter what setting (low=warmer or HIGH=COLD) or what time of day if it's 3 am or 12 noon, the air conditioner cycles on every 5 to 10 seconds.
I have taken this to the dealer several times & taken to the service center as well, both tell me this is NORMAL for the air con pump/clutch to turn on & off this frequently.
My car is a 2009 Perodua Myvi from Malaysia & this is also where I live.
The engine is a 1.3 litre 4 cyl EFI.
I have tried explaining to the dealer/service center that this is not working as it should.
Please help.....
STRESSED IN MALAYSIA
Dec 15, 2009 at 1:16 PM
  • 31,937 POSTS
Hi there, i do not have any information on this car, but what i would be doing is going to an A/C service center and having the system pressures checked this is normally the first thing that is checked when chasing an A/C problem, start here.
Mark (mhpautos)
Dec 15, 2009 at 1:45 PM
MOJAVA
mark,
I had the hi/lo checked 3 x by 2 shops both say the same thing.....this is typical.
My concern is that if the pump/clutch (cycles) too frequently ie; every 5-10 seconds that this will
wear them out faster.
It's like there is little to no variable (degree wise) for
the pump. So if it's suppose to be 25c and it hits 25.5c
then the pump kicks in.
Dec 16, 2009 at 9:40 AM
  • 31,937 POSTS
I would be thinking that the TX (thermal expansion valve) may be faulty, this regulated the release of the refrigerant into the evaporator, if it is sensing a higher them it may be causing this problem, ask your A/C shop to check this out.
See the link for the operation of the A/C system
Mark
https://www.2carpros.com/how_does_it_work/air_conditioner.htm
Dec 16, 2009 at 10:22 AM
