2005 Questions for all other cars Repeated gas leakage
2005 ALL OTHER MAKES ALL OTHER MODELS
174,000 MILES • 4 CYL • FWD • MANUAL
CLIFFORDPINTO
I have been checking the leakage with nitrogen pressure 300 pounds. I have changed the outlet pipe and changed both the inlet and outlet pins. I have also changed the gas filler. Checked the compressors bearings. Yet after filling the gas there still seems to be a leakage.
Jan 25, 2010 at 7:49 PM
DOCFIXIT
  • 18,828 POSTS
Need a leak detector add can of 134A then hook up nitrogen. Most likely evaporator leak. sniff vents for leak, condensor ect. till it's found
Jan 27, 2010 at 2:41 AM
