installing remote starter, having trouble finding a tach signal. does anyone know the pin arangement at ecm, or is there a better place to find it
Jan 2, 2007 at 9:39 AM
✓Experienced Mechanic
If it has a cylindrical coil-hook up at the neg. terminal, now if its a distributorless, find the diagnostic check connector, there you should find a pin for ign. go from there
Jan 3, 2007 at 9:17 PM
BBDG07
MEMBER
[color=blue:35d965fb19][/color:35d965fb19]great found it at can h/l diag con., thanks. got another small problem .remote start only with key in ign. off position, no key signal no start. starter over runs slightly as well, 1/10 sec or so. using a compustar1000 remote start, can-sl from fortin
Jan 5, 2007 at 1:44 PM
