2004 Sububran Driver Power Seat won't move...
2004 ALL OTHER MAKES ALL OTHER MODELS
HPGILMORE
I don't know whats wrong with it. The front driver seat will not move and niether seat will heat. The passenger seat moves just fine. Any Suggestions. I have check nearly every fuse and will check the rest in the morning when it is light out.
Mar 3, 2007 at 12:43 PM
DAVID WALKER
  • 8 POSTS
The fuse for this curcit is a 50 amp that is square and about an inch long. If you have the type wher you can view the top of the fuse you can see that it is blown. However just today I had a bad fuse and the solder connections were not shinny and there was a bad connection in the fuse.
I have had the same problem and traced it ti a wire shorting out the heated seat grid. I had to take the seat apart to repair.
Also the problem continues and it seems to be related to the 5 way switch creating a short now.
Good luck
Apr 12, 2007 at 3:40 PM
