2004 PT Cruiser power steering problem
2004 ALL OTHER MAKES ALL OTHER MODELS
KRUZIN4NOW
I have a 2004 PT Cruiser 2.4L Turbo with 70,000 miles on it and the power steering went out. At idle there is no power steering. If you rev the engine to increase the rpms you have power steering. Is this caused by a pump problem or a rack problem? If it is a pump problem, will a pump from a 2005 PT Cruiser (Turbo) work on a my 2004?
Dec 7, 2006 at 11:50 AM
CANVIS69
  • 131 POSTS
It is probably a vacume leak from the variable assist. And you need to check the pumps part number to see if the applications match if the pump isn't working after you check it out. Also cheack the fluid and the like. A rack problem is unlikely.
Dec 8, 2006 at 12:49 AM
