2004 Mercedes Benz ML 350
2004 ALL OTHER MAKES ALL OTHER MODELS
BLUE TIGER
I was told by my service advisor that I would need new brakes soon. I was interested in ceramic brake pads. I was told that they create less brake dust. Is this true? Also, would I need to replace other brake parts?
Feb 22, 2007 at 5:23 AM
CHEVY22
  • 1,375 POSTS
ceramic pads are about the best out there , you are correct less dust and longer life , most dealers here frown on cutting or resurfacing the rotors , they replace them , depending on the mileage and how many brake jobs were done you may want to consider replacing them , if you are not worried about pulsation, possible noise and undersize rotors , just replace the pads , but if the rotors are undersize or close this is a safety issue
Feb 22, 2007 at 5:27 AM
BLUE TIGER
This is the first time that my brakes will be replaced. The car has about 32000 miles. Should I replace the rotors to match the pads? Would these changes void the warranty on the vehicle? It came with a 4 year 50k mile warranty.
Feb 22, 2007 at 8:30 AM
CHEVY22
  • 1,375 POSTS
you can check with your dealer on the warranty , the pad and rotor surface should be new , as i stated the dealers here replace rotors and do not resurface them
thanks
Feb 22, 2007 at 9:07 AM
