2003 Questions for all other cars Sentra Spec V
2003 ALL OTHER MAKES ALL OTHER MODELS
KYLESCAR
The car is a sentra spec V I am told, and here is what he said is happening:
Something electrical seems to be shorting out when the engine is hot, causing a fuel cut off around 3500 rpms and also at sporatic times, causing a really rough idle. Its not the timing, its not the catalytic converter, I'm pretty sure its not the crankshaft position sensor, bc it'd throw a code.
What could it be?
Aug 11, 2009 at 1:48 AM
KHLOW2008
  • 41,812 POSTS
Hi kylescar,
I would suspect the throttle control system to be the cause. Try getting them cleaned and relearned to see if it helps.
Aug 19, 2009 at 2:17 AM
