2003 Kia Spectra alternator
2003 ALL OTHER MAKES ALL OTHER MODELS
EPWRANGLER
How do I remove the alterantor? I have the wires disconnected and the bolts off. The alternator is loose from the engine. So, how do I get it out of the engine compartment to replace it?
Jun 28, 2007 at 5:12 AM
DAVE H
  • 13,384 POSTS
REMOVAL
Remove negative battery cable.
Open B terminal cover cap.
Remove B terminal nut.
Remove B terminal lead.
Disconnect generator L and S terminal connectors.
Loosen pivot bolt and tensioner mounting bolt. Do not remove.
Relieve tension on drive belt by rotating adjustment bolt.
Remove drive belt from generator pulley.
Remove tensioner mounting bolt and belt tensioner.
Remove generator pivot bolt.
Loosen bolt at base of adjusting bracket and rotate the bracket up.
Lift generator from engine compartment.
Apr 11, 2009 at 1:21 AM
