2003 intrepid transmission
2003 ALL OTHER MAKES ALL OTHER MODELS
YELLOW05CORVETTE
Hi, I recentlu bought a 2003 intrepid with 76000 miles, the engine sounds ok but engine light is on most of the times. the problem I am having is related to the transmission. It would not shift from s\econd to third, so rpms get high. the light goes on and off. and this shifting problem is not always present. thanks
May 23, 2007 at 4:00 PM
E40WATER12
  • 522 POSTS
First thing I would do, Is get you cars trouble codes scanned, To give you a idea what sensors causing the problem, Also I would get youre transmisson filter and gasket serviced, Also make sure you use ATF 3 tranny fluid.
Good Luck.
May 23, 2007 at 9:05 PM
