2002 Ram 1500 vibration
2002 ALL OTHER MAKES ALL OTHER MODELS
HERBIE
I have a 2002 ram 1500 5.9 about 53000 miles on it. It just started to have a small vibration when accelerating or keeping a constant speed. Once I let off of the gas and it's ideling/coasting the vibration is gone, so I don't think it's the tires. Any help would be appericated.
Thanks
Jan 10, 2007 at 1:44 AM
SERVICE WRITER
  • 9,123 POSTS
Sounds like a u-joint in the driveshaft.
Do you hear a clunk when you move the shifter from park to drive? ( loose joint sign)
If so, slide under the truck, ( after you return it to park and kill the motor :shock: ) and twist the driveshaft looking for play in any u-joint. If none, it still may be the problem as it may be seizing up. In that case pull the shaft out and move the u-joint back and forth, it should have no resistance.
Jan 10, 2007 at 3:45 AM
HERBIE
Thanks...it was the rear u-joint
Jan 11, 2007 at 4:42 AM
SERVICE WRITER
  • 9,123 POSTS
Jan 11, 2007 at 9:55 AM
