2002 Intrepid 2.7 Fault Code P1776
2002 ALL OTHER MAKES ALL OTHER MODELS
THE BRIT
  • 7 POSTS
I get this code in top gear. The car jolts slightly before the warning light comes on. It goes into limp in mode. It clears itself on restart and drives normally until the next time!!!! Any ideas please. I'm thinking it is a gummed up valve in the valve body?? Would a tranny flush help??? Thanks.
Jan 12, 2006 at 3:33 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Treat the solenoid-pack repair as this owner's reported outcome. A recurrence or another vehicle with the same code needs application-specific diagnosis before choosing a repair.
Guidance references and applicability
Source: Original question and visible replies. Owner outcomes are attributed; other participants' experiences are not treated as this owner's repair. Next steps are editorial guidance, not a confirmed diagnosis.
Read the replies · Discussion summary and reported outcome
THE BRIT
  • 7 POSTS
It was the trans solenoid pack....very common. $500 fixed it...ouch!!
Mar 8, 2006 at 4:04 AM
TREVD67
hI there,
I am experiencing the same trouble code and jerking before the check engine light comes on. Where bouts did u fix it and how. My mechanic tells me that the gear box would need to be replaced and is quoting a price of approx $ 1500 to replace the gear box. $ 500 is a lot cheaper than $ 1500.
Apr 2, 2008 at 6:48 AM
Discussion summary
A 2002 Intrepid 2.7 developed a jolt, code P1776 and limp-mode operation in top gear. Restarting temporarily restored normal driving.
Reported outcome: The original owner reported that replacing the transmission solenoid pack fixed the problem.
The diagnostic measurements were not posted. A later participant's similar symptoms were not resolved in this discussion; the historical price is not a current estimate.
Read the original discussion
