2002 Ford Focus Misfire Under Load
2002 ALL OTHER MAKES ALL OTHER MODELS
CHRISJANA75
I am having a problem with my 02 focus zx3 with 135000 miles on it . it started misfiring about 3 weeks ago after my car would be running for a while and warm up to running temp and misfire. I would hear a pop from the engine so I replaced the fuel filter,plugs,wires,cleaned out my mass air flow sensor, and have been putting lucas fuel injector cleaner in for about 4 tanks now, but the problem is getting worse now it is starting to misfire a lot now not at idle but under accelaeration it pops a few times and when I am going highway speeds and try to accelerate it might pop a couple of times but mostly it does not want to accelerate.i.e.very veryslow acceleration but I put the car on a computer and nothing is showing up no codes or check engine light or nothing I am in las vegas so I don't know if the hot temp has anything to do with it but if anyone knows anything about this please respond before I have to take it in for repairs which 1 mechanic I took it to so far had no idea what it could be
Aug 17, 2006 at 6:49 AM
NOS
  • 320 POSTS
has anyone checked you fuel pressure ? are you looseing any water? may be headgasket problem started out slow but getting worse.has car ever overheated? if so suspect the headgasket. cars don't run on water in fuel or otherwise. (NOS)
Aug 20, 2006 at 6:50 AM
Suggested Repair
Check fuel pressure and look for coolant loss or a history of overheating, which could indicate a head gasket problem.
Conversation Summary
A 2002 Ford Focus ZX3 with 135,000 miles began misfiring after warming up, then worsened under acceleration with popping and very slow highway acceleration. No codes or check-engine light appeared after plugs, wires, the fuel filter, MAF cleaning, and injector cleaner. The expert suggested checking fuel pressure and coolant loss, and suspecting a head gasket if the car has overheated.
