2002 F150 difficult to crank
2002 ALL OTHER MAKES ALL OTHER MODELS
MSTASZEW
I have a 2002 F150 SuperCrew with 5.4L V8 and 88,000 miles. The engine is stock except for a K&N FIPKII that was added 2 years ago. Recently the truck has been difficult to crank after sitting for some time. It seems that the cold weather makes it worse, but that may just be coincidence that he problem has started as winter approached. The truck is turning over just fine, but is hesitant to start. Once started, I can turn the truck off and restart without any problems. The other day, when it was very cold, the truck took a while to start as usual, but this time there was a very strong smell of gas in the air. When the truck cranked it had a very rough idle for 5 seconds or so where it acted like it was going to stall. The truck does not miss, hesitate, or operate poorly once started. The battery was replaced 3 months back, fuel filter 5 months back, and spark plugs changed at 65,000 miles. Thanks.
Jan 20, 2007 at 2:01 PM
2CARPRO JACK
  • 11,533 POSTS
Check for vacuum leaks at the rear of the throttle body where the pcv line hooks to the intake.The elbow cant take the heat underhood and collapses. Also might want to put a manual fuel pressure gauge on it to see where you are at press wise.
Jan 22, 2007 at 8:52 AM
