2002 Ford Explorer 4WD Engages When Cold
THESE SETUPS ARE TEMPERATURE SENSITIVE
THESE SETUPS ARE TEMPERATURE SENSITIVE[/quote:49d5ae097d] Maybe you misunderstood me...the 4 wheel drive is kicking in automatically, or its trying to...you hear the binding in the drive train like your driving on dry pavement...Only happens when its cold out, when vehicle sits over night. What do you think it can be? Like I said the the actuator was replaced already.
Thanks
I have experienced, like I said, the 4x4 will not engage or takes a little longer in cold weather. This causes the lights on the dash to flash (4H-4L).
You may want to have that checked!
Suggested Repair
Have the 4x4 mode switch and the GEM module checked. Flashing 4H and 4L lights indicate the system is not completing high or low engagement, and these systems can be temperature sensitive. The transfer case actuator has already been replaced, so check the switch and the GEM, which is typically inside the instrument panel.
Conversation Summary
The owner of a 2002 Explorer with automatic 4x4 says the system engages or tries to engage below about 30 degrees, especially after sitting overnight. The 4x4 high and low lights flash and the drivetrain binds. The transfer case actuator motor was already replaced. The expert explained that flashing lights mean engagement is not completing and that these systems are temperature sensitive, then suspected the mode switch and recommended also checking the GEM module that works with the switch.
