2002 Dodge Durango Heater Only on High
2002 ALL OTHER MAKES ALL OTHER MODELS
WALLY DENIKE
I just noticed that my car heater motor only works on High speed, there is a telltale clicking like it's trying to work on the first three speeds. question is:
Where is the heater motor so i can check the motor for voltage coming in.Just below the glove box I see what looks like the bottom of a motor with some wires going in. yes----no?
Nov 8, 2006 at 6:42 AM
BOOTDOG
  • 665 POSTS
the problem is in the resistor. i know in some ealier models the resistor is located behind the dash at the very top in the center, right near the windsheild. when a resistor goes bad you'll loose the other fan speeds. i would change out the blower motor too. it's been known that the blower motor can cause the resistor to go bad.
Nov 8, 2006 at 9:29 AM
Suggested Repair
Replace the blower motor resistor, which commonly fails and leaves only high speed. Also replace the blower motor, since a failing motor can cause the resistor to fail. On some earlier models the resistor is behind the dash at the top center near the windshield.
Conversation Summary
The owner of a 2002 Durango reports the heater blower works only on high, with clicking on the lower speeds, and asks where the motor is to check incoming voltage. The expert says a bad resistor causes loss of the other fan speeds and recommends replacing both the resistor and the blower motor.
