2002 Chev Venture thermostat
2002 ALL OTHER MAKES ALL OTHER MODELS
DCASEYINWA
My van's heater has been acting up, it will work one day and then just blow cold air the next. The temp guage was working just fine not running hot or anything. Just recently it has started to register hot while running at a stop. I was thinking it might be the thermostat and wanted to replace it but my manual doesnt show me where it is located. Am I on the right track and can you tell me where to find it?
many thanks :roll
Apr 3, 2007 at 7:05 AM
LILWILLS
  • 49 POSTS
check ur fan clutch
Apr 3, 2007 at 11:22 AM
REBELCHEVY57
if your van has the 3100 or the 3400 the thermostat is at the back (driver side )of the intake follow the upper radiator hose the thermostat housing is in between the cross over pipe for the exaust and the engine it has two 13mm head bolts attaching it
May 5, 2007 at 10:57 AM
