The stock engine blew big time. I picked up a used engine from the junk yard, installed it and now I get a hard to start, barely running rough engine with only one trouble code. The code P1391 says that the signal from/too the crank and or cam sensors is intermittent. I have checked the sensor per the manual, they get 5VDC and cycle as the engine is turned over by hand.
Is there any way to check the PCM? Can I take just the module and get it tested or do they need the whole truck? To get the truck down there I would have to have it towed 50 plus miles, and that is not cheap.
Thanks.
Dru.
SPONSORED LINKS
Sunday, February 5th, 2006 AT 1:56 PM
