How difficult to adjust clutch. Where is adjustment located?
Feb 3, 2007 at 9:24 AM
BRUCE HUNT
✓Experienced Mechanic
You know I don't believe there is any adjustment as the old cable or push rod type clutch systems had. What is the problem you are experiencing?
Feb 4, 2007 at 2:12 PM
SHIREK
MEMBER
I just need to remove somef the freeplay in the pedal
Feb 7, 2007 at 5:59 AM
DBARRAS
MEMBER
Hydraulic clutch, no cable
Feb 7, 2007 at 7:57 AM
BRUCE HUNT
Have you checked the fluid level in the reservoir and the play on the pedal as in a loose connection of the pedal? It is possible you have early stages of a master or slave going out.
