2000 Questions for all other cars Stalling
CLEGGY
  • 2000 ALL OTHER MAKES ALL OTHER MODELS
Engine Performance problem
2000 Questions for all other cars Two Wheel Drive Manual 76000 miles
I own a Rover 45.
When I start the engine from cold it Start/runs perfectly, after a minute or so it will start to choke/idle irratically, if left will stall.
If I set off straight away, at first it will be fine, then there will be no power. Once the engine has run/warmed up it works fine.
This problem also occurs when the engine has run for sometime and then left for about half an hour or so, but the power loss is quite severe.
I have had to computer specialist look at my car, one said there was 50+ errors and the could not be cleared, there other one said he could not fine anything wrong, even when the created an error.
I have also had the CPU tested, no errors report
Can you advise on what the problem might be.
Tuesday, September 23rd, 2008 AT 2:36 AM
KHLOW2008
  • 41,814 POSTS
Hi Cleggy,
Erractic idling and stalling when cold could be due to
1. ECT
2. Ignition coils, cables and spark plugs.
3. Vacumn leakages
4. Crank sensor
I don't think it is possible to have more than 50 + errors and the car can still be driven.
Saturday, September 27th, 2008 AT 11:38 AM
CLEGGY
Thank you for your response,
I found the test report at the weekend, it was actually 27 errors being reported.
I have my car booked in at a test centre on Friday, I shall pass your comments on.
Cheers
Cleggy
Monday, September 29th, 2008 AT 1:57 AM
