2000 Questions for all other cars high frequency low amplitu
2000 ALL OTHER MAKES ALL OTHER MODELS
RCDAS
Shakes or Wobbles problem
2000 Questions for all other cars 4 cyl Front Wheel Drive Manual
My car MRUTI SUZUKI- MODEL -WAGON-R VXI, 100234 KM, AFTER REPLACING ALL SPARK PLUGS, SUSPENSION REAPIRING WORKS, WHEEL BALANCING AND ALGINMENT AND REPLACEMENT OF FRONT SHOCK ABSORBERS, I FEEL A HIGH FREQUENCY BUT LOW AMPLITUDE VIBRATION IN MY HEART AND ALSO IT CAN BE FELT BY TOUCHING THE TOP OF GEAR HANDLE WHICH WAS NOT THE CASE BEFORE REPARING WORKS. AFTER DRIVING HALF AN HOUR I TOTALLY EXHAUST.
ABNORMAL VIBRATION IS NOT OBSERVED IN THE ENGINE.
PLEASE GIVE ME SOLUTION
Oct 7, 2008 at 5:22 PM
KHLOW2008
  • 41,814 POSTS
Hi rcdas,
You need to check
Spark plugs and related pars, replacement might have been done with some wires not properly installed.
Engine mounts. If any is bad, it would cause what you described.
Gear shift bush, might be worn resulting in excessive slack.
If the problem only happens with relations to rpm, the above would be likely cause.
If driving only the problem appears, you need to check driveshafts.
Oct 11, 2008 at 5:31 PM
