1999 Ford F150 EGR Hesitation
1999 ALL OTHER MAKES ALL OTHER MODELS
MRUPPE2
I have a 1999 F150 with a 5.4 V8 engine. The Service Engine Soon light recently came on and I had the computer code taken off at Autozone. The first time they told me that I needed a new EGR valve. The light then went off after a few times driving and i got the code checked again and a different person said I needed a new EGR sensor. While driving at a low speed with constant easy pressure on the accelarator it will hesitate and jump a bit. Which problem is most likely? If it is the EGR sensor, where is it located? Thanks.
Mar 9, 2006 at 11:55 AM
PEPPERMRJ
  • 1,158 POSTS
[quote:f777bbbb92="mruppe2"]I have a 1999 F150 with a 5.4 V8 engine. The Service Engine Soon light recently came on and I had the computer code taken off at Autozone. The first time they told me that I needed a new EGR valve. The light then went off after a few times driving and i got the code checked again and a different person said I needed a new EGR sensor. While driving at a low speed with constant easy pressure on the accelarator it will hesitate and jump a bit. Which problem is most likely? If it is the EGR sensor, where is it located? Thanks.[/quote:f777bbbb92]
Ford sent out a TSB stating that any EGR related codes should be dealt with by replacing the DPFE sensor without any further diagnostics. So chances are...
If you follow the 2 rubber hoses that run up off the tube from the driver's side exhaust manifold to the EGR valve you'll find it at the top.
Good luck and let us know. :) Check your PMs. 8)
Mar 10, 2006 at 9:22 AM
MRUPPE2
Thanks! I talked to a few people and decided that this one was out of my hands. I took it to a mechanic I know and he did the diagnostics on it. Sure enough it was the DPFE Sensor. He changed that along with the EGR vacuum solenoid that was malfunctioning. It was also causing hesitation at low acceleration. Thanks again for the help.
Mar 15, 2006 at 3:24 AM
PEPPERMRJ
  • 1,158 POSTS
:D Happy motoring.
Mar 15, 2006 at 7:37 AM
Suggested Repair
For EGR-related codes, replace the DPFE sensor as directed by the Ford TSB. It is at the top of the two rubber hoses running from the driver's-side exhaust manifold tube to the EGR valve. A malfunctioning EGR vacuum solenoid was also replaced and corrected the low-speed hesitation.
Conversation Summary
A 1999 Ford F-150 5.4 had a Service Engine Soon light and low-speed hesitation. Parts-store readings alternately suggested an EGR valve or EGR sensor. The expert cited a Ford TSB calling for DPFE sensor replacement on EGR codes and described its location. A mechanic confirmed a bad DPFE sensor and also replaced a malfunctioning EGR vacuum solenoid, which resolved the hesitation.
