1999 Acura 3.2 TL P1457 EVAP Leak
1999 ALL OTHER MAKES ALL OTHER MODELS
PEPPERMRJ
  • 1,158 POSTS
Forgot to mention that here in PA. in order to pass the emmission inspection (smog test) the gas cap must be tested. I would assume this to be true around the country. Any location requiring smog testing should have test facilities, either private or state, that can test your cap.
Might be cheaper and less trouble just to order one tho. :)
Mar 19, 2006 at 6:49 AM
USMAN2006
  • 7 POSTS
I have got an Acura 3.2TL, works and performs perfectly. But there is a little problem that I have, "check engine" light is lit up. I took it to the Acura dealer they said the cat converter needs to be replaced. I have gotten the cat converter replaced as well as the O2 sensors. After reseting the check engine light it still remains lit up. The transmission was replaced back in October 2005 and now that operates just fine.I have taken it to the dealer again and they say that the computer code indicates the "Gas tank vaccume". What is that and how can I fix it to get rid of this check engine light?
Mar 18, 2006 at 1:18 PM
PEPPERMRJ
  • 1,158 POSTS
Autozone stores will pull codes free of charge. Post back with the exact code. It has something to do with an emmision control reffered to as the EVAP system. This system includes several items, the gas cap, solenoids, vents, sensors, etc. There are also 15 or more seperate codes if memory serves.
Good luck and let us know. :)
Mar 18, 2006 at 3:55 PM
USMAN2006
  • 7 POSTS
Below are the codes I have got from Advance auto parts scanner.
[b:c61956440f]DTC (Codes)
P1457
Manufacturer Contrl.
Auxiliary emission controls[/b:c61956440f]
Please let me know what should my next step be.
Thanks
Mar 19, 2006 at 4:32 AM
PEPPERMRJ
  • 1,158 POSTS
[quote:a975c9a537="usman2006"]Below are the codes I have got from Advance auto parts scanner.
[b:a975c9a537]DTC (Codes)
P1457
Auxiliary emission controls[/b:a975c9a537]
Thanks[/quote:a975c9a537]
P1457 Leak Detected In EVAP Control Sys.(EVAP Canister Sys.) (Acura)
I'm not personally familiar with acura only codes. Generic OBDII codes that are similiar are PO440 thru PO455. They narrow the field of possible offending componenets down considerably.
The (EVAP) emission control system prevents the escape of fuel vapors from a vehicle's fuel system. Fuel vapors are routed by hoses to a charcoal canister for storage. Later, when the engine is running a purge control valve opens allowing intake vacuum to siphon the fuel vapors into the engine.
The most common leak is a loose gas cap. Also refueling while the engine is running can set this code. If there are no driveability issues I would remove the gas cap and reinstall it. Then reset the codes and see if it returns.
A gas cap is pretty high tech nowadays. It is both a vent and a pressure release valve. I have had one fail and had to simply replace it to solve a PO442 code.
The next step would be to inspect the canister, tubes, and hoses for leaks or damage. A hole as small as 1/16th is enoiugh to set a code for a small leak.
After that the valves and vents would be suspect. Not to common tho.
Try the cap and let us know. Good luck. :)
Mar 19, 2006 at 6:41 AM
Suggested Repair
Reseat the gas cap and clear the codes. If P1457 returns, replace the gas cap, then inspect the EVAP canister, hoses, and tubes for small leaks before checking the purge valves and vents.
Conversation Summary
The owner of a 1999 Acura 3.2 TL with about 122,500 miles has a check engine light that remained on after the catalytic converter and oxygen sensors were replaced. The dealer described the fault as gas tank vacuum, and a scan showed P1457, an EVAP canister system leak. The expert said a loose or failed gas cap is the most common cause and recommended reseating or replacing it, then inspecting the canister, hoses, and related valves if the code returns.
