1998 Isuzu Trooper Transmission Fill
1998 ALL OTHER MAKES ALL OTHER MODELS
DCASTI13
my question is where does the transmission oil go cannot find where it should be poured
thanks
May 6, 2006 at 10:39 AM
JOUGH626
  • 55 POSTS
Manual or Automatic?
If it is manual, there should be a bolt/plug, about 1 1/8", on the passenger side of the transmission. Fill it so the oil flows out of the hole and put the plug back in. Done.
Automatic, if you have a dipstick tube, you can just pour it down there. Just be sure to not over fill it.
Jun 17, 2006 at 10:12 AM
Suggested Repair
Identify whether the transmission is manual or automatic. On a manual, remove the roughly 1-1/8 inch fill plug on the passenger side, fill until fluid begins to flow out, and reinstall the plug. On an automatic with a dipstick tube, add fluid through the tube and do not overfill.
Conversation Summary
The owner of a 1998 Isuzu Trooper could not find where to add transmission oil. The expert explained that a manual transmission is filled through a passenger-side plug until fluid overflows, while an automatic is filled through the dipstick tube without overfilling.
