1997 Questions for all other cars Instrument lights
1997 ALL OTHER MAKES ALL OTHER MODELS
54,000 MILES • V8 • 2WD • AUTOMATIC
OPTIMISTBRE
What is the instrument light on the dash that says, "ABS" for? What are the most likely causes if this light staying on even when the engine not running and the key out.
Aug 4, 2009 at 2:28 AM
KHLOW2008
  • 41,814 POSTS
The ABS is the anti locking brake malfunction indicator if it stays on while vehicle is running.
With engine off and the indicator light is showing means there is an electrical fault somewhere. Could be a bad ground wire somewhere, did you happen to reverse install the battery?
It could be a faulty ABS control unit that is shorting and this would result in battery drain.
Aug 4, 2009 at 6:06 AM
