1997 Neon
1997 ALL OTHER MAKES ALL OTHER MODELS
DHOLMES
I have a 97 neon that will turnover but will not start up. I
have replaced the cam shaft sensor, the computer twice,
checked the crankshaft sensor and all fuses. The coil pack ohmmed out good. What else is there that I have overlooked.
Dec 29, 2006 at 9:44 AM
STRATUS98
  • 96 POSTS
Check the plugs and wires to start, also check fuel rail for gas pressure. With what you have said, I think the issue is spark or fuel. let us know how this turns out
Dec 29, 2006 at 11:21 AM
SERVICE WRITER
  • 9,123 POSTS
Timing belt issue? If it cranks faster than is normally seemed to, I'd pull the cover back enough to see if the belt is turning.
Dec 29, 2006 at 12:25 PM
