1997 Maxima SE - dashboard lights dimming
1997 ALL OTHER MAKES ALL OTHER MODELS
SRPETERMANN
My 1997 Maxima SE's dashboard night-lights began dimming on the climate control head and then the problem spread to the certain sections of the Bose stereo over the last 2 yrs or so. Currently the night-lights of the climate control head are completely out as are those on 1/2 of the stereo. The local dealer said both units need to be replaced. This sounds like too easy of a solution. Does anyone know what the possible cause is? Both units still work fine except for the lights that illuminate the buttons at night. THANKS!
May 16, 2007 at 10:18 AM
KAMO
  • 47 POSTS
Mark down your fuses, run to an autoparts store and pick them up, try just replacing them. A Voltage meter and a factory service manual are also very handy if this does not fix the problem. Use a volage meter and check the lines goin to each unit, check the battery cables, alternator, and the actual physical condition of the lines themselves.
May 18, 2007 at 11:21 PM
