1997 ECLIPSE GS
1997 ALL OTHER MAKES ALL OTHER MODELS
PAPPY123
I have a 1997 mitishibishi eclipse gs with 105,000 miles on it. When first started there is no somle but if it is allowed to warm up for an extended period of time it smokes a light bluish/white smoke for about a quartermile. Also if sitting idleing for 4 to 5 minutes and start driving again the same thing occures. Ives checked the compression and it was fine. Ive also replaced the valve cover gasket . If anyone knows whats wrong any advice would be greatly appreciated. thanks
Feb 19, 2006 at 10:28 AM
2FASTECLIPSE
[b:1dab4541fa]i had the same problem in my other eclipse and if i where you i would check the valve seals and/or your piston rings, that was my problem.[/b:1dab4541fa]
Feb 22, 2006 at 4:51 PM
ALTERED119
i have a 1996 eclipse with the same problem, i tried several different things, but i had the valve seals replaced and that was 6 months age and wow, no more smoke! the 500 bucks i spent was worth it.
Feb 24, 2006 at 3:27 AM
