1997 astro
1997 ALL OTHER MAKES ALL OTHER MODELS
KMCLEAN
i have a 97 astro van. it stopped running and i cant figure out why it wont start.i replaced the fuel filter and i can hear the fuel pump come on when i turn the ignition on so i think it is getting fuel. what should i do know?????
Jan 26, 2006 at 12:32 PM
KENVCR
  • 105 POSTS
When was your last tune up. Complete change of all spark plugs, new cap and rotor. Is your van a TBI unit or Fuel Injection. Vortec motor? If you can hear the fuel pump running then your problem will be "electronic" related. Try changing your plugs, cap and rotor. Under the cap check for excessive amounts of rust around the base of the distributor. Use 100 grit minimum strips of sandpaper to clean off the rotor shaft, don't forget the top. Vacuum this dust out. Wipe it clean and ensure it it dry. Install your new rotor and cap.
Feb 1, 2006 at 7:30 AM
CHEVY350GUY
  • 109 POSTS
i would also check fuel pressure and regulator. just to prove your fuel system.
Feb 2, 2006 at 4:23 AM
