1996 Geo Tracker Clutch Stall
1996 ALL OTHER MAKES ALL OTHER MODELS
CHEVYNUT
I have a 96 tracker with 136.000Ks.My problem is when I put my clutch in the rpm drops to 0 then stalls it does that every time i come to a stop sign.I heard this is a common problem with the 1.6 Liter engine.People tell me to tack the EGR valve off and clean it becauce it is plugged with carbonis that true
Jun 1, 2006 at 7:58 AM
LOSONE
  • 1,616 POSTS
Nope, you have a serious clutch problem either the throwout bearing or pressure plate. It is not a common problem until the clutch is bad. Good luck
Jun 1, 2006 at 8:29 AM
CHEVYNUT
what does the clulch got to do with ideaing some times when i put the clulch in it goes to 900rpm sometimes 300rpm then some times it goes to 0rpm that when it stalls.It is realy bad on hot days it goes down to 0 all the time.I talked to GM thay said it is the EGR valve pluged.Some master Tech I hope i do not get you to work on my car
Jun 1, 2006 at 2:43 PM
LOSONE
  • 1,616 POSTS
Let me put it too you this way. After 40+ years of garage ownership the 0 RPM condition has to do with something in the clutch set up. Yes an EGR valve that needs cleaning has to do with erratic idle.
I would clean the EGR orfices as well as the throttle body. It too can cause erratic idle. Use a small tooth brush and carb cleaner in the throttlebody. The engine will idle a little rough after a start because of injecting the cleaner.
Once the erattic idle is stabilized and the RPM stills goes to 0 you have a clutch problem
Remember we are here to answer questions and we am not standing by your car to do a hands on diagnosis as we have to depend on what you write. There is no substitute for the sound and feel of an engine. That is 50% of the troubleshooting arena.
Good luck
Jun 2, 2006 at 12:11 AM
INTERVALKID
1.6 liter geo tracker 1996.
I need to clean the screen in my egr valve but every mechanic, except for the Chevy dealers, who charge a ridiculous fee just to read the electrical diagnostic tool.
Where is this thing in the car? I would like to find some schematics but have had no luck. HELP!
Adrian
May 7, 2007 at 2:25 PM
Suggested Repair
Clean the EGR orifices and throttle body with carburetor cleaner and a small brush. After the idle stabilizes, if RPM still drops to zero when the clutch is pressed, inspect the clutch, including the throwout bearing and pressure plate.
Conversation Summary
The owner of a 1996 Geo Tracker with a 1.6L engine reported that pressing the clutch at stops drops the RPM to zero and stalls the engine, especially on hot days. A dealer suggested a carbon-plugged EGR valve. The expert said erratic idle can come from dirty EGR passages or the throttle body, while a consistent drop to zero RPM after cleaning points to a clutch problem such as the throwout bearing or pressure plate. A later request for the EGR screen location was not answered.
