1996 F150 washer fluid not working
1996 ALL OTHER MAKES ALL OTHER MODELS
BILL42
  • 5 POSTS
I have 1996 F150. The washer fluid will not work. Wipers work, fuse is good, I can hear the click when I attempt to use the washer fluid but to no avail. Please help, it's winter in Michigan & we love our salty roads!
Please hold the non squirting jokes to a minimum.
Thanks
Bill
Dec 4, 2006 at 11:54 PM
BRUCE HUNT
  • 3,754 POSTS
There is a pump to push the fluid to the windshield. It is possible that it has failed. I would have the motor tested. You need to see that it gets power to run and if it is getting power I would suspect the motor.
Dec 5, 2006 at 1:25 AM
BILL42
  • 5 POSTS
Bruce,
Where is the pump located? How can I test for power? The clicking noise I hear is that some sort of relay or the pump itself?
Bill
Dec 5, 2006 at 1:47 AM
BRUCE HUNT
  • 3,754 POSTS
I am not sure on that but I would suspect it is in close proximity to the washer resevoir. You could follow the sprayer hoses to the resevoir from the outlet nozzles. Using a volt meter on the electrical connection determine if the voltage is there when the washer is activated. Might be a good 2 person job. Power there pump is probably bad. No power you go to the switch, etc.
Dec 5, 2006 at 3:37 AM
