1996 dakota 4wd shifter
1996 ALL OTHER MAKES ALL OTHER MODELS
BSTORM0698
1996 dakota sport 4x4 V8 5.2L 318 when trying to shift into 4wd, my shifter inside the truck has a hard time going into gear. It used to slide right in with a little pull, now I have to really pull and push to the side for it to go into gear. When going out of gear again I have to pull to the center and really give it a push forward to disengage. What could be the cause of this and how could I address fixing it?
Mar 5, 2007 at 6:52 PM
RETIREDAUTO
  • 46 POSTS
sounds like you might have some rust on shifter mechanicm/linkage.you have to get under the veh and spray the shifter and linkage then move it thru the shift range several times. tou may need to do this a few times before it loosens,hope this helps
Mar 6, 2007 at 5:51 PM
