gasoline coming out of exhaust LOTTS OF IT, drivers side sparkplugs worn right down pasengers side looks good .Car runs rough engine light on.
Feb 24, 2007 at 9:50 AM
CHEVY22
✓Experienced Mechanic
i would start by doing a tune up , replace plugs check all ignition components and replace as needed , start it up and see what happens and let us know , take care of the obvious first and we will go from there
thanks
jim
Feb 24, 2007 at 12:04 PM
ABJESS289
MEMBER
changed plugs, car is still flooding. feul is still coming out the exhaust.
Feb 24, 2007 at 10:56 PM
CHEVY22
do you have spark to those cylinders ???
Feb 25, 2007 at 1:48 AM
ABJESS289
MEMBER
car runs,used portable tester. it said missfire in number 6 cylinder.
Feb 25, 2007 at 6:36 AM
CHEVY22
i there spark to that cyl and what did you replace so far
jim
Feb 25, 2007 at 6:39 AM
ABJESS289
MEMBER
JUST THE PLUGS, DON;T HAVE TIME FOR ANYTHING ELS TODAY,RELATIVES OVER
Feb 25, 2007 at 7:11 AM
CHEVY22
ok we need to check fire and fuel to that cyl
Feb 25, 2007 at 7:23 AM
ABJESS289
MEMBER
ALL CYLINDERS ARE GETING FEUL. ALMOST LIKE TOO MUCH FEUL.
Feb 25, 2007 at 7:35 AM
CHEVY22
maybe we need to check the pressure and see if the regulator is bleeding down or allowing high pressures
Feb 25, 2007 at 7:38 AM
ABJESS289
MEMBER
IM THINKING COIL
Feb 25, 2007 at 7:54 AM
ABJESS289
MEMBER
FEUL , REGULATORNEVER EVEN THOUGH OF THAT.TOMORROW IS ANOTHER DAY, THANKS.
Feb 25, 2007 at 7:58 AM
CHEVY22
thats why tou need to check everything , especiallt to #6
MERLIN2021
You more than likely have a burnt exhaust valve in 6
