1995 VW Passat
1995 ALL OTHER MAKES ALL OTHER MODELS
CHENANI
I have a 95 vw passat GLS that has not been driven or used in about 2 years. I am now in desperate use of this car and am trying to make it run. I know to change the battery however are there other suggestions I should do before I go to use this car?
Jun 5, 2006 at 12:04 PM
SYNCRAIT
  • 235 POSTS
drain as much gas as you can from the tank and fill it up with fresh gas..... gas tends to go bad after about a year of sitting....also i would reccommend just changing all the filters ie. fuel, air , oil, and check all the fluids ie. coolant, oil
Jun 5, 2006 at 12:12 PM
