1995 Questions for all other cars Gears grind
1995 ALL OTHER MAKES ALL OTHER MODELS
LOGANNEEL
Transmission problem
1995 Questions for all other cars 4 cyl Front Wheel Drive Manual 1500 h miles
Replaced a clutch, pressure plate, throw out bearing in a forklift. Gears grind when attempting to put it in gear. Adjusted the clutch little-by-little untill there was no more pressure to the flywheel. If I adjust the clutch enough to stop the grinding there isn't enough pressure to move the vehicle. When I back it off enough to get pressure to the flywheel the gears grind. What am I doing wrong?
Jun 22, 2010 at 10:04 AM
KHLOW2008
  • 41,814 POSTS
Hi Loganneel,
Were the parts replaced of the correct type?
Jul 4, 2010 at 5:38 AM
  • 31,937 POSTS
What type of car is this?
Mark (mhpautos)
Jul 26, 2010 at 7:05 AM
