1995 Questions for all other cars AC
1995 ALL OTHER MAKES ALL OTHER MODELS
RMB68
Water from ac was leaking in floor.I took of the panel where the water was coming from and it was filled with water.I took off drain hose and replaced it because it was old but it is still leaking and the compartment that houses the heater core(I am not sure if it is called a heater core but they look like two small radiators) is still filling with water.Do you have any ideas why it is still leaking water?
Oct 21, 2008 at 12:12 AM
MIKE H R
  • 3,094 POSTS
When you changed the drain hose di the water drain out. I may be clogged and what you have is it has to go somewher so it comes in the car. You can takeoff the drain hose and use a coat hanger and clean the inside a little so it drains.
Dec 16, 2008 at 11:10 PM
