1995 Chevrolet Lumina Axle Clicking
1995 ALL OTHER MAKES ALL OTHER MODELS
KARNIECLOWN
Why when in gear it climbs to 30 Mph in 2 seconds the drive axel i beleive? it started with makin the clickin/popin noise while turning please tell me more about whut it may be
Jan 28, 2007 at 4:34 PM
SERVICE WRITER
  • 9,123 POSTS
Sounds like you have a cv joint that failed. You'll need to get an axle put in.
Climb under and take a look in the front. There is an axle on both sides that go from the transmission to each wheel. On both sides of each axle, there are rubber bellowed boots that protect the cv joints. Look for one of them ripped as a tell tale sign of which axle.
Jan 28, 2007 at 9:41 PM
KARNIECLOWN
thanks it was a half shaft on the right side cv boot was bad
Jul 18, 2007 at 7:59 AM
SERVICE WRITER
  • 9,123 POSTS
https://images.2carpros.com/forum/automotive_pictures/30961_happyhottie_3.jpg
Woo Hoo!!! another satisfied customer!
Jul 18, 2007 at 9:03 AM
Suggested Repair
Inspect both front drive axles and CV boots. A torn boot or clicking/popping while turning indicates a failed CV joint; replace the affected half shaft, which was confirmed on the right side.
Conversation Summary
The owner of a 1995 Lumina van reported that it was not moving properly, climbed quickly in gear, and made clicking or popping noises while turning, suspecting a drive axle. The expert said a CV joint had failed and advised inspecting the front axles and rubber CV boots for a tear, then installing a replacement axle. The owner later confirmed the right-side half shaft had a bad CV boot.
