1995 geo prizm turn signa and flasher failure
1995 ALL OTHER MAKES ALL OTHER MODELS
OIII88
  • 31 POSTS
I just purchased a 1995 geo prizm for my wife. The turn signals and hazard lights stopped working. I changed the flasher fuse under the dash and that did not fix it . Is there another fuse that could be causing it ? I was told it might be the turn signal switch its self but I can not see that being a problem considering the hazards and turn signals work of diffrent switches. Any help would be greatly appreciated. Thanks < sorry I know I asked it once but kid deleted it thinking he was closing it.:|>
Mar 17, 2006 at 5:53 AM
PEPPERMRJ
  • 1,158 POSTS
Check the fuse under the hood. It is # 15 in a US corolla. The lid to the box should have a listing. Hazard-horn 15 amp. Looks can be deceiving, use on ohm meter or test light.
Sharing of fuses, fuseible links, and circuit breakers are common to conserve space and wire. Check even what might seem unrelated. Also the circuit breakers on these vehicles have to be manualy reset.
Good hunting and let us know. :)
Mar 18, 2006 at 3:08 PM
OIII88
  • 31 POSTS
How do you manualy reset the ciruit breaker?
Mar 18, 2006 at 5:24 PM
OIII88
  • 31 POSTS
thanks for the fast responce now i got to try and locate the darn thing I know nothing of these foreign electrical systerms . And on autozone I cant find the breaker under componant location.
Mar 19, 2006 at 3:10 AM
PEPPERMRJ
  • 1,158 POSTS
Did you try the fuse first. Use the navigation on their site to show the electrical box locations. Should have 1 or 2 under the hood drivers side front and 2 inside the cabin.
Mar 19, 2006 at 3:16 AM
OIII88
  • 31 POSTS
Just wanted to update you all.. I got it fixed today. Turns out when the mrons installed a new stereo. They unplugged the flasher switch itself for the Hazards. I removed the little face place while putting in a new radio and the wire dropped down I plugged it back into the hazards button and the signals now work... Anyways thanks for all the help you all offered. :D
Apr 30, 2006 at 5:50 AM
