1993 SL1 w/ 220,000 miles temp gage rising
1993 ALL OTHER MAKES ALL OTHER MODELS
BARREL
My temp gage has been rising since the weather has gotten warmer. the previous owner said he replaced the thermostat recently and i purchased the car in November 2006. i have not run the AC at all yet and the temp gage usually sat at the 1/4 mark during the cooler months. the car has not has any visual antifreeze boil over but i did have to top off the antifreeze a couple weeks ago and there was no change in the temp gage effect. When the temp rises, the car idles lower than usual. What should i be looking at?
May 8, 2007 at 8:06 AM
2CARPRO JACK
  • 11,533 POSTS
Does the cooling fan come on? Sounds like the previous owner installed a lower than called for t-stat. Have a 195 degree t-stat installed and go from there.
May 8, 2007 at 8:29 AM
PEPPERMRJ
  • 1,158 POSTS
Hey BARREL,
Just to give you some reference , my 96 satty runs close to the 1/2 mark most of the time. The cooling fan will come on at about 3/4 and shut off a little before it gets down to 1/2.
Keep an eye on the coolant level and watch for any signs of overheating.
Good luck and let us know. :)
peppermrj
May 8, 2007 at 4:58 PM
BARREL
Would i be able to use my AC without problems at this time with my temperature issues or would you all suggest I wait until i change the t-stat to the 195 degree one?
May 10, 2007 at 2:08 AM
