1992 Questions for all other cars Water not returning
1992 ALL OTHER MAKES ALL OTHER MODELS
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
ANTONIO32
  • 9 POSTS
Hi guys,
I have a Mistubishi Magna Sedan; one month ago I changed the radiator thermal switch because the fan wasn't coming on. That was fixed ok. Later on though, (could be coincidental), the water from the reservoir started to not return into the rad. I have no idea why this is happening. Any ideas? Appreciate any comments -Tony
Mar 4, 2009 at 8:59 AM
  • 31,937 POSTS
HI there, test and replace the pressure cap if found to be faulty.
Mark (mhpautos)
Mar 4, 2009 at 9:29 AM
ANTONIO32
  • 9 POSTS
[quote:4f1649dbc1="mhpautos"]HI there, test and replace the pressure cap if found to be faulty.
Mark (mhpautos)[/quote:4f1649dbc1]
Will do, thanks Mark;
If found ok, is there a next step?
Thanks again
Mar 4, 2009 at 10:00 AM
  • 31,937 POSTS
HI there, just pressure test the cooling system and check that is it holding pressure, the cap is what controls the pressure and the flow into and out of the surge tank.
Mark (mhpautos)
Mar 4, 2009 at 10:08 AM
ANTONIO32
  • 9 POSTS
[quote:e1ae756fc0="mhpautos"]HI there, just pressure test ...
Mark (mhpautos)[/quote:e1ae756fc0]
Ok done, thanks Mark, the reservoir lid was cracked. Will send you some money in a couple of days, you ve been very helpfull. Merci again -Tony
Mar 5, 2009 at 9:00 PM
