1992 MB 190e
1992 ALL OTHER MAKES ALL OTHER MODELS
1990BENZDRIVER
[/b]I own a 1992 MB 190e. My problem is that it will not strart without pressing the gas, and as soon as I get off of the gas it shuts off. I can drive it as long as I hold the gas constantly, what should I look to attempt to solve this problem
Nov 28, 2006 at 9:38 AM
GMFACE
  • 23 POSTS
Have you had your fuel pump pressure checked recently, or have you changed your fuel filters?
To start, I would check your fuel lines, filters, and pump. If those are alright, I would take a look at the fuel distributor...
If I remember correctly, Mercedes has an electronic valve on their fuel distributor that helps control fuel supply at idle. If the valve is bad, you'll normally hear a buzzing sound coming from it, and the engine won't start well or idle. The valve is costly at around $300, but it's best to find an entire used fuel distributor online (ebay?). Usually they sell for just a few dollars, but just make sure the valve is still on the piece. It may even be your fuel distributor.
A friend of mine had a similar problem, and after changing his fuel distributor (including the electronic valve), the engine would respond again.
Jan 3, 2007 at 3:44 AM
