1992 Crown Victoria ignition
1992 ALL OTHER MAKES ALL OTHER MODELS
DSAHM
The key got jammed in the ignition so bought new switch(cylinder and keys) and will replace the whole thing. Is there anything special to this? I'm assuming it's a pretty straight forward swap.
Apr 28, 2007 at 11:23 AM
MERLIN2021
  • 17,250 POSTS
You'll need a sterring wheel puller. Seperate the two plastic column covers, if you can turn the key turn it to expose the small hole insert a pin and pull it out!
Apr 28, 2007 at 2:15 PM
